Mobil Fluid 424 vs. Shell Spirax S4 TXM
   / Mobil Fluid 424 vs. Shell Spirax S4 TXM #1
csm6795
Opinions on which would be best for CK27 gear
   / Mobil Fluid 424 vs. Shell Spirax S4 TXM #3
   / Mobil Fluid 424 vs. Shell Spirax S4 TXM #4
The one that costs the least.
All I know is that I just did my 50 hr maintenance and the spirax quieted the hst substantially. I can't speak to the mobil, but I assume its specs are similar to shell and it's also a recommended replacement oil. I agree, buy what's cheaper and give it a shot.
   / Mobil Fluid 424 vs. Shell Spirax S4 TXM #5
Is your HST loud? I might have had a little noise with my CK30 HST, but the DK45 HST makes NO HST noise. You must be enjoying that cab, you're really racking up the hours fast!
   / Mobil Fluid 424 vs. Shell Spirax S4 TXM #6
Either fluid is recommended by KIOTI Tractor. If it was a HST, we would recommend the Shell Sprirax. We have had excellent results with the Spirax (Donax) in HST Transmissions.
Thanks for the replies. The local wally world carries the Spirax so it looks like that's what I'll be using. Thanks again!
   / Mobil Fluid 424 vs. Shell Spirax S4 TXM #9
I wouldn't say loud, but it had a whine that's now gone. Seems smoother too.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
