Mobil DTE heavy oil iso 100
   / Mobil DTE heavy oil iso 100 #1
popcorn3
cheshire UK
none at the present
I'm looking for a little help. I've told to use Mobil DTE heavy oil iso 100 in a piece of equipment I need to service but will only need a small amount so di not wish to buy a huge amount that I can see for sale on the web. I know nothing about oils so is there something else I can use. I have found another iso 100 oil but do not know if they will match up. Any suggestions would be appreciated.
   / Mobil DTE heavy oil iso 100 #2
not a good idea being iso 100 doesn't necessarily mean that the other characteristics match just within the mobil brand there are several dte oils that are different from each other with that designation. to shorten it up check the other characteristics on the label make sure they match
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2012 MACK CXU613 (A53843)
2012 MACK CXU613...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
