Backhoe MMM with backhoe?
   / MMM with backhoe? #1
jfhall
New Hampshire
Kubota B7610
I've heard people talk about the compatibility between the MMM and backhoe. Can you use both? What I heard was the brackets for the MMM got in the way of the subframe. Is this true, can the brackets be removed, or is there any other way around it. I've been leaning towards the MMM, but would also want a backhoe at some point.
   / MMM with backhoe? #2
From what I understand, you may use both without interference. The MMM locks up in position when you use the backhoe if I remember right, or you only remove the deck, but the dealer members can tell you for sure. John
   / MMM with backhoe? #3
There may be a compatibility issue if your backhoe uses a mounting system that stays attached to the tractor when the backhoe is removed. In the case of my New Holland a MMM would not be feasible with my backhoe.
I don't see a problem using a MMM and a backhoe that uses a 3-point mount system.
   / MMM with backhoe? #4
So the Kioti does not use a full subframe? (They should be) If it does they you can't use a MMM at the same time.
   / MMM with backhoe? #6
No you can not run the (full frame) subframe backhoe and mid mount mowers on the Kioties together.
   / MMM with backhoe?
I was referring to the CK20HST. I'm aware that I would need to remove the deck so the subframe for the backhoe could be attached, but I guess the question is would the mounting brackets for the deck interfere with either the mounting brackets for the subframe or the subframe itself.
Thanks for all of the replies and info...
   / MMM with backhoe?
Do the mounting bracket for the MMM get in the way of the subframe also? I don't mind removing the deck when I have to use the backhoe...
   / MMM with backhoe? #10
yes the brackets are in the way..... Its one or the other...
I guess this is one of those cases where you are not allowed to have cake and ice cream at the same time.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A51219)
2002 WESTERN STAR...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
