MMM spindle greasing
   / MMM spindle greasing #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I lube the 3 fittings on my 7-Iron deck twice a year but always wonder how much grease to pump in. Would anyone know what is recommended? After about 120 hours of mowing I have pumped in a lot of grease but never seen an indication of excess grease being expelled so I assume the spindles are a sealed unit.
   / MMM spindle greasing #2
I try to lube my spindles a little more often--every 5-10 mowings, which is every 3-5 weeks. I can hear the air "crackle" out of the bearing race/seal when I have pushed enough in. This is typically 20-25 pumps on my one-handed pistol-type grease gun. The number of pumps might mean nothing depending on the type of gun you have.
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
Generac Generator (A51691)
Generac Generator...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
