MMM Maitenance
   / MMM Maitenance #1
Anonymous Poster
Epic Contributor
Does anyone have any suggestions as how to easily and conveniently access the blades on a 72"MMM for sharpening? On the tractor I can get to the outside blades but the center blade is a problem. Off of the tractor it is a bit heavy to flip over like I can do with the 54" deck from my 425. Any suggestions would be appreciated.
   / MMM Maitenance #2
I have used 2 different ways to lift the deck to a nearly vertical position for removal of the blades and cleaning: (1) Use the loader, and (2) Use the rear 3 point hitch with a boom pole or pallet fork. I connect the deck to the lifting device with sling straps. Leave the lifting tractor engine running while you are working on the deck to prevent leak-down or a quick drop. I also prop the deck up with a 2 x 4 for additional security. Be careful.
   / MMM Maitenance
I never gave it a thought when I decided I "needed" a 72" MMM, my old 60" I could lift up against the wall but this thing would make the veins stick out too far on my neck. I ended up getting a chain hoist from Grizzly for about $40 and it works great. I hang it over a ceiling joist close to the wall and tip up the deck, top towards the wall.
   / MMM Maitenance #4
Doug,I run our tractors up on a set of car ramps to remove and sharpen blades.It works fine for me and is a big time saver.
   / MMM Maitenance #5
<font color=blue>Doug,I run our tractors up on a set of car ramps to remove and sharpen blades.</font color=blue>
Just the standard, one piece, ramps you can get at an auto store? Have you ever tried sharpening the blades while they're on the deck?
   / MMM Maitenance #6
Yes,standard ramps from the parts store.You about need 4WD to climb up on them.No,I always remove the blades,clean the build-up off,sharpen and balance.I have sharpened the blades on our rotory cutter while still on the machine,but that's it.
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2023 JOHN DEERE 7R210 LOT IDENTIFIER 88 (A53084)
2023 JOHN DEERE...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
10' CONTAINER (A51248)
