MMM lift stopped working
   / MMM lift stopped working #1
andyny
Last weekend I installed the 3rd SCV kit on my 4210, and hooked my 72" MMM up to it. I tested it a bunch of times as I reassembled the tractor, and it worked fine. This evening, I went out to do some mowing. Lift worked fine when I started, but after I mowed for about an hour, I went to put the tractor away, and discovered it would not lift the deck anymore.
The hoses alternately stiffen up like they should, and there seem to be no leaks. Everything sounds normal when the valve is engaged. I tried the rockshaft, and it seems to get very sluggish on the way up, but otherwise seems OK.
I have not hooked up the FEL yet, which would be wise, but I won't have time till the weekend.
About 2 weeks ago, the dealer did the 50 hour service which included new filters and fluid. The fluid level is above half way on the sight glass.
The symptoms seem to indicate possibly a clogged suction side filter, but thats a guess. Could be air in the lines from installing the 3rd SCV, but I don't know what to do about that.
Any ideas?
Thanks,
Andy
   / MMM lift stopped working #2
I have had a similar problem with mine. It was cockpit error. I forgot to loosen the depth stop on the adjustable lift rod. Make sure it is turned full counter clockwise so that the lift stop is disengaged. See page 19 of the Operator's Manual.
Bill
Turns out that the pin that attaches the end of the ram to the lift assembly fell out. It was sitting on top of the mower deck. I went to the hardware store and spent $0.32 on a new hairpin clip and washer, and was back in business in about 10 minutes.
Andy
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
Ditch Witch 350Sx Tractor (A50322)
Ditch Witch 350Sx...
Year: 2010 Make: Chevrolet Model: Malibu Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 (A51694)
Year: 2010 Make...
GMC 3500 Ambulance (AS IS)(NO TITLE) (A50774)
GMC 3500 Ambulance...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
