MMM in the way?
/ MMM in the way? #1
bikemiser
Bronze Member
East Central Illinois
Kubota BX1830
Do I have to remove the MMM to drain Hyd. fluid and change filter on a BX ? /forums/images/graemlins/confused.gif
/ MMM in the way? #2
You could but it would be harder to do than getting it out of the way. I would just move it.
/ MMM in the way? #4
Take the MMM off and slide it out from under the tractor. Your going to need a large pan to catch the hyd fluid and the mower will be in the way.
/ MMM in the way? #5
</font><font color="blue" class="small">( Do I have to remove the MMM to drain Hyd. fluid and change filter on a BX ? /forums/images/graemlins/confused.gif
)</font>
Do you have to? No, I think you can reach both the filter and the drain plug with the mmm attached. However, I can't really think of any practical way to catch the oil either from the drain or the filter with the mmm in the way. I think the job will be much easier and neater if you remove the deck. It really is a pretty simple process. Plus, while it's off you can clean and inspect the under side of the mmm much easier and reach the greasing points easier as well. I know my mmm collects a lot of grass under the deck and it's difficult to get it properly cleaned without removing the deck.
/ MMM in the way? #6
The filter on mine was so bloody tight that I needed all the room to get at it as possible. You *could* change the hydro oil with the deck on, but the deck comes off so easily, why bother? /forums/images/graemlins/confused.gif
Edit: Reply was ment for the origional poster, sorry.
/ MMM in the way? #7
I recommend taking off the MMM for that change. More
room to work, room for the drain pan, etc.
/ MMM in the way? #8
)</font>
It's not a problem so I don't bother with taking it off and putting it back on.
/ MMM in the way? #9
</font><font color="blue" class="small">( Take the MMM off and slide it out from under the tractor. Your going to need a large pan to catch the hyd fluid and the mower will be in the way. )</font>
I've drained the hyd fluid twice.
I use a large drain pan under the tractor and have room to spare with the mower on the tractor and the mower is not in the way.
There is no need to remove the left rear wheel to clean the hyd screen either just as there is no need to take the hood and engine shroud off to change the engine oil.
2015 HAMM H11IX PADFOOT ROLLER (A64279)
2015 HAMM H11IX...
2005 MACK CV713 MIXER TRUCK (A63569)
2005 MACK CV713...
SKIDDED PLAIN/WASTE WATER TANK (A63569)
SKIDDED...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
