MMM Deck height ajustment on BX2230
   / MMM Deck height ajustment on BX2230 #1
lstumper067
Bronze Member
North Mississippi / Nash Ridge
Kubota BX2230/Ramrod mini skid loader/Carlton stump cutter
Hello everyone,
6 hours on the Bx2230 and everything going well.
But I did want to ask anyone else who has one, /forums/images/graemlins/confused.gif a question.
I find that the height adjustment knob is very hard to get into the "top" position (even when the deck is fully rasied as it shoud be for making adjustments) you just about have to force it on my unit. can adjustments be made? any comments would be appreaciated....
stumper
   / MMM Deck height ajustment on BX2230 #2
Stumper; I don't know about an adjustment, but you have to make sure that the MMM is all the way up. I raise the deck up until the lift lever returns, and then I lift it up holding the lever and turning the knob until it reaches TOP. hope I have explained this well enough for you to understand.
Will
   / MMM Deck height ajustment on BX2230 #3
The method to make this adjustment is in the owners manual. This is a common problem. Try rocking the deck when turning to get to the top position. If this doesn't work, then follow instructions for adjustment in the book....
   / MMM Deck height ajustment on BX2230 #4
I also do this same procedure with my 1800. The lift returns to center before the deck is truly all the way up. So I lift it another time and then have no problems.
   / MMM Deck height ajustment on BX2230 #5
Same here, the lift control on my BX2200 will return to center before the deck is all the way up.. TBN helped me figure that one out... just grab the control again and hold it up until you "hear" the hydraulics top out... mine was actually on it's way back to the shop before I figured that out.
- Patrick
45006 (A48082)
45006 (A48082)
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A48081)
2014 Utility...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A48992)
2008 V.E...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A45679)
2019 VOLVO VNL...
Terex TSR-50 Skidsteer (A48837)
Terex TSR-50...
