RebelYell
Bronze Member
- Joined
- Jul 27, 2003
- Messages
- 83
- Tractor
- Kubota BX22
I am not good at reading directions and/or following directions. I can usually study something for a bit and figure it out, after I mess it up real bad, /forums/images/graemlins/smirk.gif. However, the caster settings in the manual seem to contradict themselves. The manual shows to have the caster 1/4'' to 1/2'' off the ground at lowered position. The manual also shows a table for rolling terrain which indicates if you are mowing at 3 inches then to have the peg in the 3rd position down. and if you mow at 2.5 inches then 2nd position down. IMO this tabe is backwards. Any one elses opinions on this would help. I live in TN, and alothiogh my land is flat, I have no flat spots to check my blade and caster levels.
