MMM Cart
   / MMM Cart #1
Mayor
Eastern, PA
With the grass growing so fast and cutting 2 times per week plus the projects I have going on. I am switching back and forth a lot from FEL to MMM. I had to make some kind of cart to help my back out. We all know the switch over is easy and the deck comes off in a few seconds but I need to store it up right in my garage. Let me know what you think? I use the FEL with hooks to drop it in the holder but the pipes can be removed really easy.
   / MMM Cart #2
Great idea!
I usually just lean it against a wall in the barn, but have to chock it up with a couple bricks so it won't fall over. Your cart is a good safe way to store and move it.
   / MMM Cart #3
I like it.. How did you / what did you use to install the uprights?
brian
   / MMM Cart #4
I bought the mower axles from Larry a few years ago. They are worth every penny...
You can view my pictures HERE
   / MMM Cart #5
Those mower axles look like a good idea too. How do you install the axles? DO you have to lift the deck up and remove the existing anti-scalp wheel and the install the axle? How does the second wheel attach to the axle?
   / MMM Cart #6
Loogie,
You just need to lift the deck a little to drop out the anti-scalp wheels, then slide the axles in, and put the pin in place. The wheel is held on with a small spring clip.
No tools required, and only take about 1 minute per side taking your time. The deck is extremely stable when in the upright position.
   / MMM Cart #7
I second the mower axles - they are a bit pricey but they are very well built and work well. I use mine for longer term (winter) storage.
Scott
   / MMM Cart
brian
Just some pipe and mounting plate. I think I have $30.00 in it with the cart.
   / MMM Cart
Looks like a great idea.
Galvanized steel fence (A53424)
Galvanized steel...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2009 International Prostar (A53314)
2009 International...
