MMM Blade sharpening recommendations
/ MMM Blade sharpening recommendations #1
danbike
How many times a season/how many hours do you go between sharpenings of the blades on your deck?
/ MMM Blade sharpening recommendations #2
On a Scag ZTR doing 4 to 5 acres at our church in NJ, I sharpened the blades every time I finished the mowing, which generally took about 3 1/2 hours.
You want to keep the blades sharp doing grass.
Ralph
/ MMM Blade sharpening recommendations #3
Personally, I don't go by hours or seasons. I just look at, and feel the edge of, the blades and sharpen them whenever they appear to need it, and it's convenient for me to do it. I sharpened my mower blades yesterday. They'll be 2 years old in August and hardly needed sharpening because now I don't have any gravel, rocks, etc. to dull them as I've had in the past. /forums/images/graemlins/wink.gif
/ MMM Blade sharpening recommendations #4
Bird, that's the correct method, because using hours or seasons doesn't take into account what the blades actually look like. When I am mowing only grass with my 7-Iron deck the blades stay sharp for at least 50 hours, or 2/3 of my mowing season.
But if I do a lot of rough cutting in overgrown tall grass which has tough weeds, wild grapevines, and anthills it shortens the time between sharpenings to half that much. I do that mowing on my ATV trails as late as possible after all my regular lawn mowing is caught up with.
I cut a hole in the top floor of my barn about 30 inches square that is covered with a trapdoor, and I can access the underside of the MMM and remove the blades in 5 minutes from the basement area. When I think of all the time I wasted driving up on ramps and struggling to remove and replace the blades, I want to kick myself for not thinking of the trapdoor idea sooner.
/forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/tongue.gif
Like I have said before, this particular group of people know how to get a job done in the most efficient manner. Even when helping out someone with a large garden tractor. Great idea, I'll use the ramp idea since my barn has a concrete floor. I probably should have had an access pit done when we poured the floor, but that is another story. /forums/images/graemlins/smile.gif
/ MMM Blade sharpening recommendations #6
Removing your mower would be very easy to do then you can clean the bottom of the deck and under the side shields good. For sharpining, if you have an angle grinder it goes much faster than using a bench grinder. If you get a lot of burs then go back and touch it up with the bench grinder.
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2000 Bobcat 863...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Cub cadet LTX1045 Lawn Mower (A63116)
Cub cadet LTX1045...
