ML265 bucket sizes
   / ML265 bucket sizes #1
Tim_in_IA
Platinum Member
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
When my 6500 was delivered it had a regular mount bucket on it. I had ordered a quick tatch skid steer compatible version, which they put on and delivered to me last weekend. Just looking at the bucket it appears to be a bit shorter and looks like it would handle less material. It lists that is a 78" like the other, but are there cubic material size options as well? I just didn't know that I would be downgraded to a smaller size bucket for the quick attach option.
   / ML265 bucket sizes #2
TIM, The bucket width should be 78" with or without the quick tach.
right, the width is the same, but due to the bucket construction difference is the cubic ft the same? The width is 78" for both as you stated.
As a followup I checked with my dealer and there was only one 78" bucket available (from Mahindra).
   / ML265 bucket sizes #4
Tim, my 6000 has the 78" bucket from KMW. I believe it is rated at 23 cu. Ft (27 cu/ft being a "yard"). Not sure what the volume of the quick detach is. Bobg in VA
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
International 1086 Cab Tractor 2wd (A52128)
International 1086...
Year: 2021 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 26,631 Plate: Body (A50323)
Year: 2021 Make...
