ML106 Loader parking stand - build it myself?
   / ML106 Loader parking stand - build it myself? #1
rando76
Claremore, Oklahoma
2008 Mahindra 2816, Massey Ferguson 165, Ford 9N, Ford 8N
I have a 2008 Mahindra 2816 with a ML106 loader. I bought it used and it didn't come with a parking stand, so I can't remove the loader. I talked to my local dealer, he thought they were unavailable but were $155 + tax + Shipping IF he could get it! I thought that was a little high for a piece of pipe with a foot on it! :( I'd like to build my own. Does anyone have a ML106 with a stand that they could measure and take a picture of?
Thanks!
   / ML106 Loader parking stand - build it myself? #2
Did you figure this out? If not I will measure mine for you.
No, I haven't built one yet or found one to measure. I'd really appreciate it if you would measure yours.
   / ML106 Loader parking stand - build it myself? #4
I bought a removable loader 21 years ago. I took the loader off once in those 21 years. The parking stand is in the shed, left where I took it off 20 years ago. ;)
   / ML106 Loader parking stand - build it myself? #5
Mine is 30 inches long ... the pin hole is 3 inches from one end the other end has the foot on it.
Thank you! It will be super easy to make. I'm having a problem with my loader dropping. Yes, I'll fix it, but it'll get worse before I do and I'll want to mow. That's how I got to needing a stand.
   / ML106 Loader parking stand - build it myself? #7
Unless you'll be able to park it on a slab or driveway, you should figure-in for a piece of wood under the foot - I use a small square of 3/4" plywood. If it sinks into the ground at all it can be a little pain to reattach it, I've found. Also parking in the shade is very helpful for hydraulic pressure build-up in the hoses & cylinders and disconnecting them when the temp is up helps. The first time I had the heat problem I took a wood mallet and hit the poppet balls to relieve the pressure so I could connect the hoses and ended-up getting a hydraulic oil bath. Only took me the one time to learn to wrap a large rag around them if you have to tap them open !!
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
2014 Chevrolet Equinox 2LT SUV (A50324)
2014 Chevrolet...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
