Tires Mixing R-1 with R-4 tires
   / Mixing R-1 with R-4 tires #1
k4330
Bronze Member
poconos pa
Kubota 5030 hst
I have a K4330 with R-1 tires and the fronts are not holding up. I have shale on my property that I dig with the machine to use in the driveway and so on and it tears the **** out of the R-1's .. My question is can you get R-4 tires to match the same hight as the R-1 Which is needed with the 4X4? ..Thanks
   / Mixing R-1 with R-4 tires #2
I don't think that you will be able to find the right size. They would have to have the same rolling circumference or very close to keep the front to rear ration correct. You could dig on the tire manufacture site to find out the RC of your present tires and then look to see if they have any R4s of that size.
Detach Trailer (A50514)
Detach Trailer...
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
