Mixing of UDT & Super UDT
   / Mixing of UDT & Super UDT #1
Anonymous Poster
Epic Contributor
I am about to change the hydraulic oil in my Kubota mini-excavator (which only hold 4 gallons) and have thoughts of using the super UDT. I am sure the machine does not have super UDT in the machine. Does anyone know if you can mix super UDT with any other hydraulic fluid? Since I purchased the machine used I am not sure of what is in the machine now.
Thanks...
Jon S.
   / Mixing of UDT & Super UDT #2
Collapse any of the hydraulic cylinders as much as possible when you drain the system. The fluids are compatable and WILL mix readily.
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
2014 Ford Explorer SUV (A50324)
2014 Ford Explorer...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
100 gal Water Tank (A50515)
100 gal Water Tank...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
