mixing concrete
   / mixing concrete #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
So what is the consistency the concrete should be for fence posts? I have been mixing them by hand. When I do about a gallon of water to an 80lb bag the concrete is all wetted but still fairly dry consistency. This does pack well when tamped. If I add just a little more water the concrete starts to get some flow characteristics to it. It is a little soupy when tamping in the hole. So if I am going to take the time to mix the concrete instead of just adding it dry to the hole what consistency should it be?
To keep this tractor related I am digging all the holes with a 3PH post hole digger. They are getting straighter.
   / mixing concrete #2
You want to use the minimum amount of water possible when mixing concrete. This usually means a stiffer mix than most people think. Try to mix it so you can pick up a handful, and it stays in an open hand without running off. It will still work fine for posts, if it a little soupy.
If you get frost where you are, do not run the concrete all the way top the top of the hole. Stopping about 4 inches from the top will dramatically decrease the chances of the frost popping them out of the ground.
If your using wood posts, I suggest only using concrete on the ends. The concrete usually facilitates rotting. You can simply pack stone around the intermediate posts.
   / mixing concrete #3
For setting posts I mix to the consistancy of damp sand. If you can make a ball & it holds it's shape & leaves your hand barely damp that's just right. Tamp it around the posts & it'll hold them upright and cure to high strength. This is essentially the mix used in gunite systems, for free form swimming pools, tunnel or mine shaft lining, etc. Any water added beyond that will loose some ultimate strength but gain ease of use for pouring, etc.
Another tip to reduce frost heaving is make the bottom of the hole slightly bigger than the top & keep the sides as smooth as possible. MikeD74T
   / mixing concrete #4
I recently put concrete in about 45 post holes, using 80 80lb bags. I went the other way, as I really did not want to tamp and figured I would sacrifice a little strength for ease of use.
I tried to get my mixture to the consistency of a thick stew or slightly running oatmeal. That way, when I poured it in the hole, it would flow around the pole and fill the voids, aided by some hand vibration of the pole. After cleaning out the hole by hand (tractor did the bulk of the digging) and often using a dig bar to get a few more inches into rock, the last thing I wanted to do was hand tamp concrete. The poles would easily retain their position with this consistency after 20-30 seconds in the holes. (Note that this averion to tamping was a theme for me, and because I used a tensioned fence I did only minor tamping on the line poles, as the corner poles were all in concrete with supporting cross braces).
   / mixing concrete #5
Most of the commercial fencing installation crews I've seen don't even bother pre-mixing/wetting it out...they set the posts with dry mix tamping it in then either soaking it or not even bothering allowing mother nature to finish the job...
   / mixing concrete
Thanks for the help. It sounds like I am on track. I have mixed it a little soupy when I needed it to flow into areas that were difficult to tamp. I did do the dry method for the vinyl posts since they will only see stress when pushed on not like a tensioned fence. The line posts are going to be pounded so I only need to put concrete in the corner and brace posts.
   / mixing concrete #7
That's the best way I've found. Concrete don't get any harder than that.
   / mixing concrete #8
I too have allways put some rocks in first to hold the post where I want it and prevent the concrete from making a cup below that post and then just pouring dry, right out of the bag in next and maybe some more rocks on top. If I am feeling it I might run a garden hose over it or run around with a 5 gallon bucket, but throwing it dry sure is easier....
   / mixing concrete
So having an inch or two of concrete under the post is going to be bad?
   / mixing concrete #10
The problem with concrete below the post is it can form a cup that fills with water and rots the post quicker. If you tamp some rocks/gravel in there first it helps the concrete to form a ring which drains better.
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2007 DOOSAN G25 GENERATOR (A53843)
2007 DOOSAN G25...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
