Mitz 2050FD Fuel Assembly Leaking/Raditor Hose
   / Mitz 2050FD Fuel Assembly Leaking/Raditor Hose #1
Coachnic
Suwanee, Georgia
Mitsibushi D2050
Last year I noticed a leaking coming from around the screw that holds the fuel bowl and filter in place on the Fuel Assembly unit. I pulled it off and saw that the ORing was not in the best of shape so I ordered a new one and replaced it. Still, I noticed after running the tractor for an hour or so, it was still leaking from around the O Ring running down the fuel bowl. I then replaced the whole fuel assembly, bowl and O Ring and now it's still leaking from around the bowl after running it for a while.
Is there anyone else having this problem with the 2050FD's and if so, what have you done to repair it.
Lastly, I am in need to replace a small hose that connects from the bottom of the radiator and runs to the petcoack drain plug. Is this just a simple hose I can pick up at a local parts dealer or do I have to special order it?
   / Mitz 2050FD Fuel Assembly Leaking/Raditor Hose #2
The hose can be bought at any parts store, just take a piece with you. Can't help with the fuel leak.
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
205028 (A52706)
205028 (A52706)
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
