Mitsubishi/Satoh ST2020 Oil Recommendations and capacity
   / Mitsubishi/Satoh ST2020 Oil Recommendations and capacity #1
Glyn Finch
Greer,SC
Mitsubishi ST2020
I need to know what type of oil to use and the capacity of a Mitsubishi/Satoh/Kumiai ST 2020 tractor. Also, the engine temp light comes on after about 30 minutes of use, but the radiator is full. Any suggestions as to what to check?
   / Mitsubishi/Satoh ST2020 Oil Recommendations and capacity #2
Hi Glyn Finch,
I bought my tractor (Satoh ST2020) in 2005. Since 2005 I am using 10w40 STOU oil for the tractor. Unfortunately I don't have any manual for the machine, so if you have more precise information, please let me know.
STOU oil is suitable for both motor and gear box. As I remember it is needed ~20 liter of oil by the gear box and other 4 liter of oil by the motor.
By the way I have the same symthom as you. It can be suspicious the cooler/radiator (use only distilled water for it) or the heat detector.
I had earlier the same problem, but at that time the outer surface of the radiator was coverd by cottonwood. Check it and clean it if it is necessary!
   / Mitsubishi/Satoh ST2020 Oil Recommendations and capacity #3
Glyn, for motor oil use 15W-40 Shell Rotella or Chevron. For hydraulics, does yours use the same reservoir for transmission, hydraulics and rear? If so use hydraulic/gear oil. There is a Satoh/Mitsubishi forum here too. Welcome.
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2008 Ford Ambulance (A47477)
2008 Ford...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
