Mitsubishi MT372 Mule Pulley Belt Tension Adjustment
   / Mitsubishi MT372 Mule Pulley Belt Tension Adjustment #1
goinnorthsoon
Litchfield, Maine
1984 Mitsubishi MT372
I have a 1984 Mitsubishi MT372 and I have just replaced the mule pulley drive belt. When it is engaged, the pulley guards get really hot after just a few minutes of use. I noticed the bar was out of the adjustment area (in between the arrows where it is stamped run). I made an adjustment on the threaded rod attached to the engage lever. I'm right at the end of the threads and the bar is about on the top arrow now, when engaged. Any ideas? Belt too short? The new belt is 109" and the old measured 109.5". Any help would be appreciated. Thanks.
Eric
   / Mitsubishi MT372 Mule Pulley Belt Tension Adjustment #2
Some pictures might be helpful. I'm having trouble envisioning this.
I found the manual and instructions so I'm all set with that. I do need to cross reference the vbelt. It is off a Haban MTM48 belly mower for the mule pulley, part number 14323. Does anyone have a cross ref or an original belt length? Thanks.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
NEW Slip On Fork...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
