Mitsubishi MT2201D tractor with front loader possible buy
   / Mitsubishi MT2201D tractor with front loader possible buy #1
Ruud3a
Latvia
Iseki TL 2300 F 1985, Case IH 1056xl, Belarus 825
Hello guys!
I have some plans to buy a Mitsubishi MT2201D tractor with front loader.
What are the problematic places to look for? What are the weak places for this tractor? I need it for smal jobs in my farm.
Second option could be Yanmar tractor with almost same power and with front loader. Which one do you choose and prefer? My thoughs prefer that Mitsubishi tractor because it is quite local to me.
Thanks guys. Welcome with your advice and opinions. :)
   / Mitsubishi MT2201D tractor with front loader possible buy #2
I know nothing about the MT2201D other than it runs a Mitsubishi four cylinder diesel as does my D2350. The weakest link on my Mitsubishi has been the hydraulic pump. In the last fifteen years the shaft seal has gone out twice putting hydraulic oil into the crank case. The pump itself hasn't failed, just that seal. Replace the seal and you're good to go. If your glow plugs use that resistance coil thing to drop voltage keep an eye on it. The resistance wire can corrode keeping power away from the glow plugs making hard starting. My tractor was overheating but a good cleaning of the cooling system seems to have fixed that. If you do happen to need parts or support try Valley Power
   / Mitsubishi MT2201D tractor with front loader possible buy #3
So, did you get the bull?
Rusty cooling system is indeed the first problem you'll face but it can be easily fixed.
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
2011 DOOSAN G25 GENERATOR (A53843)
2011 DOOSAN G25...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
