Mitsubishi MT180HD - Hydraulics stuck up
   / Mitsubishi MT180HD - Hydraulics stuck up #1
meball
British Columbia Canada
Kubota B7500
I am awaiting the arrival of my slightly abused used tractor purchase. It drives fine, 4 wheel drive seems OK, hydrostatic transmisson seems ok. But the PTO does not appear to be working and the Hydraulics are stuck in the up position. This tractor has 1800 hours on it (is that a lot?). It is a US model and has a 2 speed PTO. It appears to have been rolled, the steering wheel is bent, the seat is bent and the PTO shield is bent. Any ideas on how to fix the Hydraulic, PTO issues? Not sure where to start. Have I bought a large paper weight, with an engine?
thanks,
Mitch
   / Mitsubishi MT180HD - Hydraulics stuck up #2
If it has been rolled over then the rod connecting the hydrolic lift piston to the lift yoat may be wedged in the housing. also there is a valve unde the seat and behind the shift leaver that may be closed, this is the lift release speed control. Pto not working could be shift leaver no working or the splined leave on the overrun clutch may be broken. none of this is very expensive if you can get the parts from salvage. West kentucky tractor parts has been a good source for me. Good luck and have fun wrenching your tractor.
Thanks Normmm! Excellent suggestions, I appreciate the help. I will post when I have figured out and fixed the problems.
Cheers : )
Mitch
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Scag Mower (A50324)
Scag Mower (A50324)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
