Oil & Fuel Mitsubishi MT16D will not start
   / Mitsubishi MT16D will not start #1
syl
I have bled the lines, replaced the fuel solenoid and a new battery. Tractor turns over but will not start. Removed the fuel injector lines and the fuel just dribbles out like there is no pressure. I'm thinking that the fuel injector pump is bad. Any suggestions or price of a new/rebuilt fuel injector pump?
   / Mitsubishi MT16D will not start #2
The system won't build any significant pressure with the fuel injector lines removed. If you want to see a high pressure spray you'll need to remove the injectors from the engine so you can see them and crank it that way. Your injector pump is the absolute last thing to check after you're positive every other thing is checked and working including compression, air filter, valves, fuel to pump, etc. Mainly because they don't fail often and they are expensive to have rebuilt. However, they can be tested for a reasonable price at most diesel injector pump service shops if you are dead-set on determining if that is the problem.
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
30008 (A53424)
30008 (A53424)
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
