Mitsubishi MT1601D Stuck Clutch and 3 Point Lift issues
   / Mitsubishi MT1601D Stuck Clutch and 3 Point Lift issues #1
docsplace
mansfield, ohio
Mitsubishi MT1601D
Hi Everyone Hope you can help me.
So I read the threads about the stuck clutch issues and I have the problem now. But that's not my main issue right now.
Last several years I have had issues with various things pertaining to the hydraulic system in this tractor. The tractors hydraulics would not work very well or at all when it got cold. I would usually have to drain the hydro oil and install new oil to get it to work. The problem was moisture in the hydro system and the screen in the resevoir was pluged with a milky looking oil clinging to the screen and not letting the oil pass thru the screen. This past year the 3 point lift would not recover and work in the spring even after changing the oil and found that the screen had started breaking up, Pieces of it were missing, I figured it had got into the system and plug the valves that set your flow control to the 3 point lift flow control, So I tried removing the flow control valve assembly that is under the seat to spray or blow it out and it would not come out, I removed the 4 bolts that hold it in and got it part way out about half inch or so and the lift started working again, So I put the 4 bolts back in and now I that valve is leaking around the plate that holds it in is leaking every time I use the 3 point hitch. I figure there is something else holding it in. I guess I'm going to have to remove it and file it flush and maybe put a gasket on it. How do I remove that flow control valve for the 3 point and while I'm at it I going ti have to get that clutch free also. I will try some of the suggestions under the other threads about the stuck clutches. Thanks in advance for any suggestions
Tom
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
2010 BIG TEX 18 TANDEM AXLE TRASH TRAILER (A53843)
2010 BIG TEX 18...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
1996 International Water Truck with a Caterpillar Engine (A55218)
1996 International...
2012 INTERNATIONAL LF687 (A53843)
2012 INTERNATIONAL...
