Mitsubishi - IH Case?
   / Mitsubishi - IH Case? #1
JazzDad
In the city now.
Main: Case 235
Anyone have a link to let me compare my 1990 IH Case 235 to the closest Mitsubishi model? Thanks.
   / Mitsubishi - IH Case? #2
Do you know which engine you have? Is it a K3-A or K3-B? The K3-A was in the Mitsubishi 373 also known as Beaver III. The B engine was in the M 470 Buck. The Buck engine has 18.5 engine hp. The Beaver has 15 or 16 I think. Otherwise both tractors have 3 speed with high and low range and 3 speed pto. There is a dealer with a website that has a link to some data that may help you. satohparts.com is the place. Edit: I just looked it up. It's a K3-B making yours most similar to the 470 Buck. I have a Buck and the gray version of the Beaver III. Good tractors.
   / Mitsubishi - IH Case? #3
It's actually closer to the MT160-180 which succeeded the early 80's Beaver and Buck. While they used the K3A and K3C engines, the frames, transmission, sheetmetal etc. are closer to yours than the older Beaver and Buck.
   / Mitsubishi - IH Case? #4
And this is the dealer. Has helped me a bunch!
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
(APPROX 80) 2" X 3" X 19 3/8" ANGLE IRON (A51247)
(APPROX 80) 2" X...
Valvoline Brake Fluid (A53117)
Valvoline Brake...
