Oct 8, 2008 / Mitsubishi D2050 lift #1 E EWhite New member Joined Oct 1, 2008 Messages 8 3 point lift will go up, but can not get it to go down, anyone had this problem on D2050 Mitsubishi?
Oct 8, 2008 / Mitsubishi D2050 lift #2 M mdr38856 New member Joined Sep 26, 2008 Messages 3 Location NE Mississippi Tractor Mitsubishi D1850 Don't know about the 2050, but the 1850 has a lever under the seat that controls down speed. If moved all the way to one direction, the 3PH will not lower. Just discovered it myself, by accident.
Oct 8, 2008 / Mitsubishi D2050 lift Thread Starter #3 OP E EWhite New member Joined Oct 1, 2008 Messages 8 I will check again, but don't believe this one has the lever under the seat.
Oct 9, 2008 / Mitsubishi D2050 lift #4 B bruceatlam Platinum Member Joined Jul 3, 2008 Messages 502 Location Camarillo, Ca Tractor LS R3039H, JD 345, JD X730 I'm not familiar with your tractor, but recently had the same problem with my Kubota. There may or may not be some helpful hints in that thread. http://www.tractorbynet.com/forums/kubota-owning-operating/124896-b20-tph-stuck-fully-raised.html
Oct 9, 2008 / Mitsubishi D2050 lift Thread Starter #5 OP E EWhite New member Joined Oct 1, 2008 Messages 8 Thanks for the help, there was a little lever underneath the seat that got moved some how. Lift works fine.
