Oil & Fuel Mitsubishi D1850FD Fuel problem
   / Mitsubishi D1850FD Fuel problem #1
Dgeorge
I have problem on starting my tractor. It will run for about
5-10 sec and then die. I changed fuel filter and get fuel through line. I do not have a manual on it so I don't want to go to far until I know what I am doing. If anyone had this problem before please let me know what you found. I do have a parts manual for it. I can use some help on this.........Thanks, Don
   / Mitsubishi D1850FD Fuel problem #2
Could it be sucking air on the low pressure side of the pump?
   / Mitsubishi D1850FD Fuel problem #3
You need to bleed the system. Start at the fuel filter and open the bleed screw and let the fuel run until it runs without bubbles. The do the same at the injection pump while cranking or running the tractor. We sell manuals that will help you with this and other problems that may arise. Bill - satohparts.com. 800-609-5110
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
(APPROX 34) 1 1/2" X 10" X 38" CHANNEL IRON (A51247)
(APPROX 34) 1 1/2"...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2016 GENIE TZ-34/20 ELECTRIC TOWABLE BOOM MANLIFT (A51247)
2016 GENIE...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
