Mitsubishi d1850 2wd - 3PH and filter ?
   / Mitsubishi d1850 2wd - 3PH and filter ? #1
mdr38856
NE Mississippi
Mitsubishi D1850
Had this in another forum, hope to get better results here.
After the tractor gets warm, the 3ph will not raise. I pulled the filter to clean it, but it needs to be replaced. Where can I get one and the seal that goes over the filter cover plate? My filter is in the bottom of the tran case. It's cylindrical about 1-1/2" dia x 5-1/2" long.
What should I use to flush the system?
I haven't noticed any fluid leaks to the pump, but there may be a very small leak at the base of one of the 3PH arms. Could this cause the power lose to the lift?
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2020 KUBOTA RTV...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
JOHN DEERE 3 BOTTOM PLOW (A51247)
JOHN DEERE 3...
2023 WESSEX RMX500 LOT IDENTIFIER 44 (A53084)
2023 WESSEX RMX500...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
