mitsubishi bd2g11 bulldozer
   / mitsubishi bd2g11 bulldozer #1
kezza1971
Karrabin Qld
mitsubishi bd2g11
Got a mitsubishi bd2g11 bulldozer how do you tighten the tracks?
   / mitsubishi bd2g11 bulldozer #2
I'm not familiar with the dozer but.....on each frame rail, there should be a tensioner that looks similar to a hydraulic cylinder. I would look for a grease fitting towards the end of the tensioner and that is used to pump grease into and extend the tensioner. Too much grease/tension, just take the nipple out to allow some grease to come out. Generally, you don't want your tracks without a little sag between the idler and carrier roller. If you don't have a manual you really need one and I'm sure these are available online. Also lots of good heavy equipment forums online with other owners that can help answer questions.
Thank you Darryl appreciate your help
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2017 International WorkStar 7300 Rosco Maximizer 3B 1,900 Gallon Asphalt Distributor Truck (A52377)
2017 International...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
