Mitsubishi BD2G Engine clutch
   / Mitsubishi BD2G Engine clutch #1
Ed.W
Southern Ohio
Kioti,kubota &mitsubishi
Last winter I tried to move my BD2G, the engine clutch slipped so bad it would barely move in 1st. gear, I checked free play, which was ok, anyone had any experience replacing the engine clutch & where did you find the clutch discs? thanks :(
   / Mitsubishi BD2G Engine clutch #2
No experience with the BD2G, but Joint & Clutch should be able to match your clutch disc, and pressure plate up. Not sure how close you are to Zanesville, but they have a pretty decent store there. There's one in Marietta also. If those are too far away, you could Google "Joint & Clutch". I'm thinking it is a franchise, and most of the larger cities in Ohio have them.
Bush Hog MB6 960 Box Blade (A53117)
Bush Hog MB6 960...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
MISC PALLET OF SPM PUMP PARTS AND JOSES (A53843)
MISC PALLET OF SPM...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
