Mitsubishi 2201 Valve Setting Question
   / Mitsubishi 2201 Valve Setting Question #1
Louisianaguy
Mitsubishi 2201D
I have owned a 2201 mitsu 4X4 for several years nows and never had a problem up until I ran it a little hot. I have been losing water after about a hour of running and noticed light foaming in the radiator coolant. I removed the head to replace the head gasket and went ahead and had the head surfaced and the valves checked at the same time. Very little was removed from the head (about 4-5 thousands) and the valves were cleaned and lapped but really did not need ground. I rebuilt the injectors (I work at a dieselshop) and changed the filters and fluids. When I cranked the tractor, I am not getting any suds in the radiator and I feels like the job was a success but it seems to have a light miss and it is hazing some light white smoke under a load. I don't know why I thought I would get away with not resetting the valves but I didn't change much and thought I would get lucky I gess....My question is: Does anyone have a valve setting spec for this tractor? Any help would be greatly appreciated . Thanks in advance!
Well, I never could actually find a setting so I took a stab at it based on some different opinions. I set them at 10 thousands and it runs alot better so I'm gonna go with that. Maybe this will help someone down the road.
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
John Deere 333E (A47477)
John Deere 333E...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
