Mitsubishi 2050 diesel tank
   / Mitsubishi 2050 diesel tank #1
TomSr
NW Arkansas
Mitsubishi 2050D
My 2050 diesel tank is leaking on the lower seam just next to the fuel hose. Does anyone know where I can purchase a new tank or is there any way to fix this one.
thanks for your help.
   / Mitsubishi 2050 diesel tank #2
G,day Tom any good radiator repair shop should be able to solder the seam for you usuallly i dont recommend that you do it yourself unless you have done alot of lead solder work as there is usually a coating on the metal and it is bloody hard to get that solder to stick properly these guys dont seem to have any probs though they should also be able to pressure test when the repair is done. I think you will find this option much cheaper than another tank best of luck:)
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
