Mitsubishi 1600D New Owner
   / Mitsubishi 1600D New Owner #1
CinOK
jd450b Mitubishi1600d
I just bought a 1600d anyone else have one of these Trying to figure out some basic info , such as where is the drain for the hyd system and is the a screen filter in the system mine has no loader also can you add remotes to it
   / Mitsubishi 1600D New Owner #2
You have a pig in a poke and I strongly encourage you to gather more information before you sink money into a loader, etc. Not that it's a bad tractor, but there is minimal support. Very minimal.
   / Mitsubishi 1600D New Owner #3
Post on the Mitsubishi forum. You might be surprised just how much info and how many parts are available if you really look. You definitely need to find out if the tractor had a US market clone. Mitsu has suppliied machinery to the US market for many years as Case, Cub Cadet and now Mahindra. There may have been other brands as well. They are very solid, relatively simple tractors which if maintained properly are faithful performers.
   / Mitsubishi 1600D New Owner #4
There is a screen filter in the tramsmsission. The hydraulic & transmission are together, so draining the trans will also drain the hydraulics. Remotes can be added to any tractor that has a hydraulic system.
New Long Forks (A53002)
New Long Forks...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
toro turf sweeper (A50324)
toro turf sweeper...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
