mitsu D2300II ?
   / mitsu D2300II ? #1
fyrcapt
Fl.
Mitsubishi 2300II
Hello, I need some help, I recently purchased a Used Mitsubishi tractor. The shell states D2300II does any one have info on this unit. I would like to change the fluids. I use rotella in my diesel truck would this be ok? Also some one told me I could reverse the wheels for a wider stance is this ok as well. Finally does any one know where I can get a manual for this machine? Thanks in advance.
   / mitsu D2300II ? #2
You can use rotella in your tractor. You can reverse the rear wheels. This is the first I've heard of a D2300II . If it looks like new & has under 100 hours ( Vietnamese reconditioned), anything is possible. Look on the left side of the clutch housing, near the top for a model # / serial #. Check the engine for a engine model. I can supply a D2300 parts book & operators & service manuals for the closest domestic models. Email me for ordering info
   / mitsu D2300II ?
The serial number seems to be M69-10294. I found the following numbers on the engine block. KE130 and 1-2451. Another question The oil cap on the transmission hump I assume its to be filled with trans. fluid? Its only one third full. I can see the gears is that normal? Also, where do I check the hydraulic fluid? I tried to email you to get those manuals but got no response. Thanks in advance.
   / mitsu D2300II ? #4
Check the fluid on the right side of the tractor midway up on the housing just behind the differential lock pedal. Yes, you may be able to see the gears. The case is normally about 2/3 full. Call me toll free 1-800-609-5110 for manuals for your tractor. Check out our web site satohparts.com. It may help you with many of your questions. Bill
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2012 L3 MEP-806B GENERATOR (A52576)
2012 L3 MEP-806B...
Electric Forklift Pallet (A50322)
Electric Forklift...
40ft Shipping Container (A52377)
40ft Shipping...
