Mits 372D Sway chains- Pictures please?
   / Mits 372D Sway chains- Pictures please? #1
GeeVee
Bronze Member
MT 372 D, ASV RC30
Anyone have pics of the sway chains? I primarily use my Tractor with a 4' bushhog, (no FEL) and sure wish I had sway chains to keep the deck from wadding up in my Rear Ag Tires.... As well, I bought a neat 3 pt frame/two position receiver hitch to move trailers, but without a sway chain, you aren't backing any trailers up. Even, I have a new ish Box blade coming to me...
   / Mits 372D Sway chains- Pictures please? #2
Neither my Mitsubishi nor my Kubota use sway chains. Both use a turnbuckle arrangement attached to the outboard side of the three point arms and then to the tractor frame. Many tractors now use a system fo telescoping tubes. You drop a pin through when you get them where you want them. You could try a turnbuckle in conjunction with your chains. They would give more variation of adjustment.
THANKS. After posting, I consulted my Parts manual, and see the factory set up was just as you described. Only like one or two links and a threaded rod into a ATR NUT, on both sides. Makes sense, the distance is pretty short. The pin shafts let you push the arm all the way inboard with a bushing, then the "linkage". I talked with Bill at VPP about these a year ago, and he relayed he had a local welder make them up as needed, but it certainly is a pair of devices I can fabricate, I just hadn't visualized it before. (Shows you how badly I haven't needed them). Yes, a small turnbuckle will probably work if there is enough distance. And I like stock and OEM, my little machine deserves the love....
He did caution me to not bend the pins, they are hard to come by? I think I will make my chains of smaller stock, so they bend or break first.... I do tend to get hung up inn small spaces.
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2006 INTERNATIONAL 9400I SLEEPER (A53843)
2006 INTERNATIONAL...
