Mitisubishi Tractor lights
   / Mitisubishi Tractor lights #1
Paul Casey
On my Mitisubishi MT372 tractor I was working under the dash trying to fix the head lights and I shorted somthing out on the idiot lights now th Oil and Overheat stay on all the time can I unplug and run without, can I fix it or do I need to replace it, and what is the P/N and cost for the part.
Paul
   / Mitisubishi Tractor lights #2
I don't think you really have any choice but to repair or replace it. Do you really want to run without knowing whether the engine is overheating or is lacking sufficient oil pressure? Both of those happen often enough that I wouldn't want to run the risk of melting the engine.
Is there any chance that you just reconnected wires incorrectly when working on the headlights?
I can't be sure about your tractor, but typically those idiot lights come on briefly when you turn the key to the "on" position. The temperature light goes out after a short time delay. The oil pressure light goes out when you actually start the engine and create oil pressure. The only thing I can imagine that could cause both lights to stay on would be if you somehow shorted both connections (to the temp and oil pressure sensors) to ground, like maybe pinching the wires against a tin cover or something. :confused:
I would begin dismantling the dash as if to replace parts, all the while looking for the problem. I think it's likely you'll be able to find and repair the problem once you open things up a bit.
   / Mitisubishi Tractor lights #3
Paul
You could just add mechanical gauges from any auto parts store
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2017 Ford Transit 250 Cargo Van (A50323)
2017 Ford Transit...
