MitD2050FD Hydraulic Problems
   / MitD2050FD Hydraulic Problems #1
kgoodwin
We recently purchased a Mit2050FD. Front end loader and rear hydraulics were working. Now the Front end loader works but the rear will not go up or down except when we manuever the bucket the rear hydraulics goes up at the same time. When we try to raise rear hydraulics, when not using front loader, sometimes the rear goes up and down, slowly and sometimes it doesn't. We have a mower on the rear 3pt hitch. We checked the hyd/trans oil by unscrewing the plug on the side. Oil ran out immediately, so we were told that if that happens it is full. What could the problem be.
   / MitD2050FD Hydraulic Problems #2
How many lines are there on your loader valve, 6 or 7? If 7, are there quick connections on the 3 main lines? What I am getting at is that if it is a PB configured valve, and you reversed the PB outlet with the return outlet, then you would only get fluid going down the return line to feed the rear when you were operating the loader(fluid returning from the loader cylinders and exiting thru the return line). Not being specifically familliar with your tractors plumbing, this was the first thing I thought of.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2013 F-550 Bucket Truck (A52748)
2013 F-550 Bucket...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
7022 (A50322)
7022 (A50322)
