Tires Minor 790 Wheel Rust
   / Minor 790 Wheel Rust #1
hardtack
Brown County Indiana
1946 Farmall B, 2001 JD 790
I noticed on my new / previously owned 790 some minor wheel rust on the rear tires. Near a seam weld opposite the valve stems on both rear tires.
I tapped the valve stems on both tires and got a clear liquid. It was slightly tacky on the fingers after drying with a mild salty taste. Obviously the R-4 tires are filled. Check the fronts and they were not filled.
My questions are.
1. Is this a calcium chloride solution?
2. Should I be concerned about the rust?
Thanks.
   / Minor 790 Wheel Rust #2
1) Yes
2) It's just a rim. You can always buy another if ever needed. Cheaper than doing a fix for your rim.
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2019 FREIGHTLINER...
24' Inline Feed Bunk (A50515)
24' Inline Feed...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A50323)
2019 International...
