Minimum HP for a tree shovel??
   / Minimum HP for a tree shovel?? #1
clarkfarm
WNY
TC24DA, 12LA FEL, 60"MMM
I am looking to add a tree shovel to a 29hp tractor's FEL.
Just wondering what kind of depth I can dig with that size CUT. Experiences anyone??
   / Minimum HP for a tree shovel?? #2
There have been a few discussions on TREE SPADES here on TBN over the years with excellent links to products. Try using the SEARCH FUNCTION and search ALL POSTS over one year and you will find them.
I think the limiting factor for using a tree spade on the FEL will be the lift capacity of the FEL.
   / Minimum HP for a tree shovel?? #3
Make sure that the manufacturer says it will work on the tractor you choose to put it on. I've seen some pretty bad breaks on the chassis components from them being installed on tractors they were not built for.
   / Minimum HP for a tree shovel?? #4
If it is designed for a skid steer & "adapted" to a compact tractor, you're best bet is one of the larger compacts such as the New Holland "class III" - TC35, 40, 45 or Deere, Kubota, etc. equivalents.
Skid steers have in excess of 2,000# lift capacities. the larger compacts have about 1,500# +/-. The 30 HP generally have a 1,000# +/-.
I know my little TC18 is best used for moving loose material, not "Digging" anything up.
Thanks for the feedback. I'm looking to lift pine trees with a 6-700 lb max rootball. My main concern was how deep will the spade go. Does that depend more on the weight of the front end than on the HP?
What kind of tracotrs did you see broken chassis on?
Thanks again.
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
378467 (A51572)
378467 (A51572)
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
EZ GO EXPRSS S4 EFI GAS GOLF CART (A51247)
EZ GO EXPRSS S4...
JOHN DEERE 1705/6700 LOT IDENTIFIER 20 (A53084)
JOHN DEERE...
