Mini-hoe usefullness
   / Mini-hoe usefullness #1
ernemats
Veteran Member
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
For you pt owners that have a mini hoe is it worth the price for using occasionally and how sturdy is it. At a weight of 93 lbs. it seems that it would not be real sturdy if that is the weight of the bucket, hydraulic cylinder, quick attach plate and the metal arm. Would you buy it again after using it for a while? What is the length and size of metal arm and does it put a lot of strain on the power trac?
   / Mini-hoe usefullness #2
I'd by mine again in a heartbeat! It's a "power shovel" with the included 9" bucket. I had some broken leach field pipes to replace last week and (having done it with a shovel about 15 years ago) it was a pleasure to spend seat time digging.
On hindsight I'd also order the 12" bucket with it, as has been mentioned by others here.... I didn't even know that getting the 12" bucket was an option but for this forum. Of course, kinda too late now as the shipping on the bucket alone would be more than if it had come along on a pallet of other PT stuff.
I used to own a Case backhoe. The PT has an advantage in that you can dig up a bucketful and then 'scoot' to where you want to dump it. Quick and easy. With a regular backhoe you dump each bucket along where you are digging, then maybe tranfer it with the FEL to somewhere else later. Yes, the Case could dig deeper and wider but the PT is able to do anything I've tried so far, short of digging the big hole that the septic tank goes into. For something that big and deep it would work but take longer and necessitate carving a "ramp" to get down that deep (the top of my tank is 3' below ground level).
Seems very sturdy. I don't get the sense that anything is nearing the "breaking point" at any time I've used it.
Phil
   / Mini-hoe usefullness #3
IMO, the minihoe is the most bang for the buck of any of the attachments. I'm approaching 100 hours on my PT since I bought it and well over half of those are with the minihoe...
It's sturdy enough that you can either raise the front end off the ground -- in a heartbeat -- or likewise, you can pull the back end off the ground if you bite off something too big to chew.... Like everything else on the PT, the hydraulics are stronger than the PT weighs.
I am planning to have reinforcements welded onto mine when I have the thumb welded on -- hopefully to prevent possibly twisting and breaking the dipper stick by picking up trees, etc...
I also would like to have a 12" bucket for digging bigger holes, but the 9" one works well... While it's not a backhoe, you can also do things with it that you couldn't with a backhoe, as Phil describes.
My friend "raves" about it because he can lower the lift arms, slide the bucket underneath the lowest wire on a barbed wire fence, then curl the bucket and uproot 2" - 3" saplings that have grown up in the fence line.... He's cleaned about 800 yards of overgrown fencerows and two acres of his woods that privet hedge had invaded and taken over...
It digs trenches, it digs up and moves shrubs, it cleans out ditches and regrades the ditch banks... It's simply handier than a pocket on a shirt.... Does that sound like I like it? /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
   / Mini-hoe usefullness #4
As mentioned already we who own the mini hoe relly like it.
Like you I bought mine thinking I would use it for a few projects but it has become one of the most used of the 15 attachments tht I own. I also like the 9 inch bucket which is perfect for the types of projects i'm now doing.
You will never regret getting the mini hoe.
PJ
   / Mini-hoe usefullness #5
I bought the minihoe to be able to plant trees and dig electric line trenches. I have used it for those tasks as well as removing old sign posts, and old fence posts, and anything else I need to dig. I own 3 shovels and have only used one of them twice since I got the mini hoe. that use was to dislodge a chunk of wet red clay from the bucket of the minihoe. /forums/images/graemlins/grin.gif
   / Mini-hoe usefullness #6
I think it is one of the best attachments I own. I have the 12" and 9", but only use the 9" when digging trenches or in areas that have lots of roots.
   / Mini-hoe usefullness #7
Odd question here, do you guys use the brakes or the treadle to hold the machine (or perhaps backdrag with the treadle) while digging?
I think the 18XX has some pretty serious brakes for hillside work, and I think the smaller units are a "ratchet lock" so maybe would hold, but I know my backhoe pretty much laughs at the brakes on the 2445. Of course, it can throw it around pretty good even with the outriggers and bucket down (working on a few solutions to that, but another thread).
Anyway, just curious. Neating reading all the uses you guys are finding for one attachment! /forums/images/graemlins/cool.gif
   / Mini-hoe usefullness #8
I just keep my foot on the reverse pedal when digging. It's a lot faster than locking that brake to dig, feathering the treadle to unlock them, turning the machine to dump the load, and then locking them again.
   / Mini-hoe usefullness #9
Brakes are useless when using the minihoe on the PT422, ppartly because they are a PIA to engage and disengage, and partly because you need to articulate the machine to dump the bucket, which generally involves some forward or aft motion.
It might be a different story if I had real brakes, but I agree with highridge; I just keep the tractor held in position by constant use of the treadle.
   / Mini-hoe usefullness #10
The first time I used the mini-hoe, I thought it was a joke. Figured I would just rent a real backhoe if I needed one.
But then.... about 3 months ago BobRip and I spent about 8 hours one day digging trenches for water, sewer, power and phone/cable at a co-workers new house. BobRip did the trencher work with his 422 and I did the mini-hoe work with his mini-hoe and my 422. About a month later I went to Tazewell and bought the mini-hoe with the 9" and 12" buckets.
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2020 CATERPILLAR 299D3 SKID STEER (A52707)
2020 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
UNUSED FUTURE FT-ECA63 ARTICULATING BRUSH CUTTER (A57193)
UNUSED FUTURE...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
