vongiese
- Joined
- Mar 29, 2002
- Messages
- 165
- Location
- NW Montana
- Tractor
- Yanmar 2210D, Sany SY35 Excavator, Kubota 4060LE,
Hi - I have a 2016 Sany SY35 excavator with 350 hours. I bought it used a year ago. It is a 8500lb machine. The Boom deflection cylinder does not work. This cylinder pivots the boom at up to 90 degrees either direction from the cab so you can dig close to buildings, etc. It is operated by a foot pedal, and when I push on the pedal nothing happens - no whine from the pump - nothing. I pulled to pedal spool valve and blew low pressure air thru all orifices (couldn't figure out how to take it apart) and all seemed clear. This valve has no solenoids. I'm stumped. All other hydraulics work normally. I don't normally need to pivot the boom, but it has slowly moved and is off angle now. Even in the interim, if I could find a way to straighten out the boom I'd be happy!
Seems like it should be something simple....
thanks for any help.
VG
VG
