Mini brush cutter
   / Mini brush cutter #1
trex232
salisbury,nc
bobcat 553
I have a Bobcat 553 skid steer, wanting to build a brush cutter if possible.The bad side is I only have 2000lbs aux pressure at 8.5 gpm. I have 2 options 1) is to build it with PTO and hyd. motor the motor I picked is Dynamic BMRS50H4KS but only figures 10 hp, my other option is to build a cutter like a Swisher rough cut mower with a hyd motor with a pulley driving a spindle an shaft with blade. Any advice would be great
   / Mini brush cutter #2
The hydraulic horsepower calculator tells me that 2000 PSI at 8.5 gpm=9.9 HP. The rule of thumb for rough cutters is 5 hp per foot. That's probably conservative, especially on the small end as the power required isn't really a linear relationship with the diameter of the cutter. But you probably want something that's at least wide enough to cover the width of the wheels, and 10HP isn't going to do that, there's no way around it.
That sounds awfully low for a skid steer. No way to get more juice?
   / Mini brush cutter
That is why I was thinking of making it like the pull behind swisher rough cut, It has a 10.5 B&S motor which I could use a hyd motor in place of a gas and run with a belt like the swisher, The hyd motor I listed above is roughly 10hp
   / Mini brush cutter #4
I just looked at the Amazon page for the 10HP Swisher. It's got a 44" deck, the reviewers say it's more of a lawn mower than a brush cutter. But that's around the size I would expect to be able to cut with 10HP. I think you're going to find you want something at least as wide as your wheels.
I think your best bet would be to get the smallest rotary mower you can find and try to adapt it.
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
