minhoe control
   / minhoe control #1
Eaglepb
Alum Creek,WV
2009 2816 Mahindra Gear Drive w/FEL 47 Ford 2N
On the newest PT425 what lever operrates the bucket curl? I thought I read that it was the PTO switch/lever. tks /forums/images/graemlins/smile.gif
   / minhoe control #2
It is the small lever to the right of and under the "dash" that otherwise locks and unlocks the quick-attach mechanism.
After mounting and locking the mini-hoe attachment you unplug the hyd hoses from the locking mechanism and hook them to the hoe. This is the circuit that opperates any attachment that uses a hydraulic cylinder rather than a motor.
Back in October of '03 "mckat" posted a slick and simple way to extend this control lever function to the upper left side of the dash. Check the archives under "Mods or custom attachments".
On my PT-1845 I drilled a hole above the valve and fabricated a new lever assembly on top between the dash console and the existing joy stick. Could be a tighter fit on a 425 though.
Rip
   / minhoe control
thanks...will check it out /forums/images/graemlins/smile.gif
7021 (A50322)
7021 (A50322)
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
