cappyD
This is what I've been working on for the past month or so. If you have ever searched for help with your Mighty Mule you probably know it's useless. There are some good troubleshooting guides out there but if your problem doesn't fit exactly in to a certain category then you are out of luck. I would get so close to a diagnosis using a guide but right at the end everything would fall apart. Usually my readings would be correct but the troubleshooting guide didn't elaborate about what to do in that case. Or it would say something like "If the voltage is between 12.5 and 14.5 the arm is good. Replace the board". I was usually left wondering why not fix the board? Or atleast give me one (or a few) things to test on the board. A new board costs over $230.00 so I'd like to be 100% sure there isn't a bad relay or something else I could fix or someone else fix. Anyway, here's my experience with the gate opener. Maybe some other person will gain something from it. Even if they learn what NOT to do.
After only a few months of having a great worry-free gate opener it bit the dust here recently. My first little issue was about 6 months ago with the slave arm limit switch. Not a big deal to remove it, clean and adjust the little spring inside of the switch.
During that time of researching gate openers I seen where a lot of people had problems with the control board. I was always careful when I had to work directly with the control board. I added a few accessories and everything was fine for about 6 months.
A month or so ago the slave arm started stopping mid-cycle for what seemed to be no reason. Soon after it started that issue it completely stopped working. Since I already had to work on the limit switch I was very familiar with the wiring for the operator arms. I did the usual troubleshooting. I swapped master with slave terminals, swapped rev counter boards, I even connected the slave motor directly to the battery. Everything checked out good. I could not find anything wrong with connections, voltage, rev counter boards, or stall force.
The only reasonable conclusion I had was something in the control board was bad.
Most normal people would just replace the control board and bypass the hours (days) of poking around with a multimeter without knowing anything about control boards. It was impossible to find schematics for the R4211 blue board anywhere on the internet. I was able to find the schematics for an older type Mighty Mule which did help me a lot.
Since I knew exactly nothing about diodes, capacitors, or resistors I couldn't definetively point to the cause of my problems. I was basically confirming voltage was present at different points. When I did think I found a problem I had no way of knowing what the correct reading should be. So I was unable to confirm any component was bad. I gave up on that after a while. That's when I came up with an idea that I never did see on the internet or anywhere else. Here goes...
So here are my symptoms and here is what I did to "fix" it.
With both arms connected in their proper terminals I push the remote and nothing moves. I can hear a click sound (relay?) and the yellow status light flashes 5 times + 1 second pause, then flashes 5 times + 1 second pause. It will continue to flash until I turn the control board off and back on.
******** It may also be giving an audible alarm of 5 beeps as well. I don't know for sure because I removed the speaker. It was very loud and CONSTANT at times.********
If I leave everything connected nothing moves. Doesn't even try. But if I remove the slave arm orange wire or green wire from the control board the master arm works fine. When I swapped master/slave terminals the exact same thing happens. So I know for sure 100% that the issue is in the control board (right??).
After probing and testing and giving up I finally tried this.
I disconnected all of the slave wires from the control board. I twisted the red and black motor wires from the slave arm to the master arm red and black wires. (Red to red and black to black)
After twisting them very tightly and carefully attatching them to the master terminals on the control board everything is back running great. I only had to adjust the slave arm closing distance manually by screwing the tube a little. Both arms open at the same exact time and stop at the exact same time.
As far as I know it seems to be safe to do this. Nothing seemed strained or weak and it sounds normal too.
There are a lot more details to this.
I've learned quite a bit about my gate opener over the past month so if I can help anyone just ask. I'm still not an electronics expert but if I can help just let me know.
********* If you know I am damaging something or if it's not a good idea to connect the slave motor wires to the master motor wires please let me know********
