Might Have to split the 990
   / Might Have to split the 990 #1
yellowsocks93
Veteran Member
MN
John Deere 990 MFWD and a few others
I may have bad news commin my way once I get the 990 checked out at work. I asked today and showed them a 990 we had on the lot where mine is leaking slowly and it is the clutch housing but no oil is supposed to be in there so they think it is a rear engine seal. That means splitting her open. /forums/images/graemlins/frown.gif And only 12 hours. After that it will be good as new maybe better since I know our techs are the best of the best.
   / Might Have to split the 990 #2
OUCH . /forums/images/graemlins/shocked.gif...Hope you are lucky and it is something else and an easy fix ....
Bill G.
I ran it around today so I could see if it would leak some more but it really did not want to leak very much. I think I might let it go for a little bit since mowing season is a few weeks away so it will get longer use then. Since it's not leaking any puddles on the floor I don't know what to do. There is a clutch drain down there where it is leaking from.
3 pt Blade (A50515)
3 pt Blade (A50515)
2016 Bobcat E32i Mini Excavator (A50322)
2016 Bobcat E32i...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
2004 Jeep Grand Cherokee SUV (A50324)
2004 Jeep Grand...
