Mig welding gas?
   / Mig welding gas? #1
Cobraone
Kubota B2650
Gentlemen, I just bought a Hobart ironman230 for fab work, I致e been Tig welding for years and have three cylinders of argon in the shop
Question is can I use 100% argon for mig or do I need c25.
I would love to use up one bottle of Argon before before refilling with c25.
Opinions please, I致e never run a mig before.
Thanks in advance for any advice provided
   / Mig welding gas?
Thanks Steve! I gave it a try, not much luck!
Maybe I can grab the tank from the kegerator ha ha
   / Mig welding gas?
Headed back to air gas, with no experience too many variables, what’s better pure co2 or c25 any ideas
   / Mig welding gas? #5
CO2 runs hotter (and cheaper) but quite a bit more spatter - I use C25 in both my migs, get maybe 1 or 2 tiny bb's - cleanup consists of sliding a stiff putty knife along flat surfaces (bb's) and a fine wire brush on a drill... Steve
   / Mig welding gas?
Yes way more spatter than tig, last time I’ve seen that much was running 6010 rod ac
   / Mig welding gas? #7
Many of the new inverter migs run CO2 pretty well. Not much spatter at all. Still you will be happier with your machine using 75% or more Argon balance CO2.
   / Mig welding gas? #8
Agree; if you wanted prettier welds than C25 (and your ironman has enough oomph) might try a bottle of 90/10 and spray mode - quick, clean, strong.
Downside - flat land welding ONLY, less than about 3/16" thick and you'll burn through. I tried it, decided I'd go back to 5/32 7018 if I needed that much brute force... Steve
   / Mig welding gas? #9
I've only used C25 and never spray arc... what again are good reasons to use 90/10?
   / Mig welding gas? #10
I use 90/10 or 92/8 for nearly everything. Short Arc , Pulse / Twin Pulse and 98/2 for Stainless. I'm not a big spray fan due to having pulse. Everyone has their own favs. Some of the higher tech brands like Fronius, Lorch, OTC, Panasonic and Sanrex weld so well on CO2 for short arc that you can hardly tell what gas they are using.
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
Pallet Fees (A50775)
