Middle Buster for ditching
   / Middle Buster for ditching #1
shade2u2
Ohio
NH TC33D
I need to bury some drain pipe for our downspouts & put in a french drain for a low area. I'm sure that this has been touched on before...
How deep does a middlebuster like at TSC dig?
Could I use this low cost implement to do what I want?
   / Middle Buster for ditching #2
There are a few threads on this under the Attachments forum. Amoung them is <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=163328&Search=true&Forum=implement&Words=drain%20tile&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=163328>Using a middle buster to bury drain tile</A>.
   / Middle Buster for ditching #3
I've just read all the posts on 'middle buster' used for trenching. I may have missed it but how do any of you guys use one of these when the tractor can't straddle where your trench is to be? I've got a middle buster and a subsoiler but it seems most of the places where i need to use them have a steep bank on one side where i can't get the plow or subsoiler down where i need it to be.
Any way of offsetting these? or some other idea?
   / Middle Buster for ditching #4
Trenchers have offset booms,I can dig 18" from
walls or use a trackhoe that has the swing boom.
Problem w/ offsetting the middle buster is it will
want to turn tractor as u pull it.
Larger tractors would be ok.
   / Middle Buster for ditching #5
After reading several posts about trenching I came across the following web site: http://www.farmshow.com/issues/250608.asp
This shows a trencher attachment to a loader bucket that would allow shallow trenching in most applications. One could build something similar without to much expense, its a very simple idea. Just thought I would mention it.
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52128)
Gooseneck...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
1999 John Deere 7810 4wd Tractor (A52128)
1999 John Deere...
