Mowing Mid PTO mower alignment
   / Mid PTO mower alignment #1
WayneW
Western Mass
Kubota B7610
Anyone else have this problem. I've read some about this is the archives, though it more or less related to the quick-disconnect on the U joint.
My problem is when I disconnect the MMM from by B7610, then want to reconnect it some time later, the PTO spline does not line up. It's keyed, like the drive shaft I guess. Thing is, it takes a while playing around with it (rotating the PTO shaft slowly) to get it the correctly lined up to the quick connect of the MMM shaft U-Joint. Thought someone might have found and east way to align the two.
   / Mid PTO mower alignment #2
I have the same problem with my snowblower, mmm, and chipper. Seems as if the splines are never in the right spot. I have been tempted to put a paint stripe or gauge mark on the shafts once they are mated that way the next time I should be able to line up the marks......think I'll try that tommorrow....
   / Mid PTO mower alignment #3
I don't know your tractor, but on mine if I put the PTO select lever in Rear Only mode, the mid PTO shaft spins freely. If I put it in Mid Only mode, the rear PTO spins freely. This helps a lot!
   / Mid PTO mower alignment #4
Waynew -
I don't know if this helps - but once I get the MMM back under my B7610 - the FIRST thing I connect is the mid-PTO shaft - this before I've connected any of the MMM-lifting brackets / what have you.
I simply turn the MMM drive-shaft gently to get the coupling "started" on the mid-PTO spline - once it slides on the first inch or so - then I slide back the coupling-ring and push it onto the PTO spline until it locks. I'm pretty sure the coupling at the mid-PTO is the same all the way around - so no problems here.
The only "spline alignment" that I've come across: the MMM spline has a single, wider spline - I think this lines up with the grease fitting of the rotating shaft.
A few times - while transporting the MMM by a strap ( Picture ) - the *outer* MMM shaft has slipped off the spline from the MMM gearbox. I found that this only goes back on ONE way. Now I use a rubber / bungee cord to keep if from slipping off.
I hope this helps,
Dan
   / Mid PTO mower alignment #5
Dan the problem is you strap was on upside down. notice tou have to stan on your hear to read the strap mane? /forums/images/graemlins/grin.gif
Thanks for that tip Dan, I'll be sure to try that arrangement next time I attempt to re-install the MMM. Sounds like a better system then what I've been doing. (don't ask)
-thanks again. I'll let you know how it turns out.
   / Mid PTO mower alignment #7
</font><font color="blue" class="small">( Dan the problem is you strap was on upside down. notice tou have to stand on your head to read the strap name? /forums/images/graemlins/grin.gif )</font>
Chucko-
Another point - I actuall carry the MMM so you can see the blades - makes a quick sharpening with a grinder or blade rotation quick & easy!
And no - it doesn't matter if the name on the strap is upside down or not! (had to re-read your post several times - "mane" = name had me confused!) /forums/images/graemlins/tongue.gif
Dan
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2014 CATERPILLAR 242D WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2012 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2012 MACK ELITE...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2005 JLG 660SJ SKYPOWER TELESCOPIC MANLIFT (A51242)
2005 JLG 660SJ...
