Mid PTO Cover
   / Mid PTO Cover #1
gusg
Vail, AZ
B7510 with R4s
Does anyone make a cover for a mid PTO? I don't feel comfortable with it uncovered doing FEL work. Thanks.
   / Mid PTO Cover #2
Hi,
When I first bought my tractor I thought there should be a cover for the mid pto, similar to that which is provided for the rear pto.
But, after thinking about it...not sure it is needed. PTO is not turning and it really out of the way normally. I don't have any reason to use it as I have a RFM.
I don't think those little plastic covers would offer any protection when doing loader work.
If you want the cover for protection, you probably need to make a skid plate of some type. I did that for the front area to protect the plastic drive shaft cover on my B2910. I also plan on making some kind of skid plate to protect the rear bottom area, but probably not until next spring at this rate.
In any event, it seems like there are other things under there that are more likely to be damaged than the mid pto, if that is your concern. Like hydraulic lines and possibly filters if the B7500 is similar to its bigger brother.
The mid pto ony turns when you have it selected, so if you have nothing under there when doing loader work there should be little to worry about. You should not have to worry about it grabbing anything, as it will not be turning, since you will not have it selected.
I have put a LOT of loader hours on mine in the last 2 months...maybe 80 ... some in rough conditions...and have not found the unguarded mid PTO to be any concern at all.
Bill in pgh, pa
   / Mid PTO Cover
Thanks. You are right that it isn't selected so it shouldn't make any difference. It should be sealed so there is no chance of getting any dust or dirt inside. I will stop worrying about it.
   / Mid PTO Cover #4
My 4100 came with a metal Spindle cover and I still got it. For some reason they had one on there for something.
   / Mid PTO Cover #5
Check with your dealer, my L3710 has a cover.
Fimco 25 Gallon Sprayer (A50123)
Fimco 25 Gallon...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
