Mid-mowers for L-series
   / Mid-mowers for L-series #1
Anonymous Poster
Epic Contributor
Anybody using the L-series with a mid-mower for lawns/estate mowing? I have a small (46") lawn mower that I use for my lawn, but I need to mow around two barns, shop, rental house and long driveway. Would you guys recommend a tractor that large. I would also like to use the mower to mow around electric fences. I have an L2850 with mid-PTO but no mower. I use it on the farm. If I get favorable responses to this and cannot find a used mid-mower, I may upgrade to a new L3010 or L3710 (Largest with mid-PTO) with GST. A lot of farms work requires shifting between L4 and H1, seems like the GST would solve changing gears and ranges. I have tried both a rotary mower (bush hog) and a rear mounted finish mower and did not like either.
I hope I have been clear and provided enough info. Thanks for any info.
Claude
   / Mid-mowers for L-series #2
I suspect you will find the consensus of this group to be the 3710 with HST rather than GST for mid mower applications. I have a gear tractor and rear bush hog mower so I am no help. I do not find myself shifting between 4 th and 5 th gear, though for any work that I do. That would be really annoying as all gears are synchronized, but I don't believe the hi/lo range selector is. Seldom need the high gears.
The pro's to a mid mount are that it is always where you want to mow when going around a lot of obstacles. The con's are that the area mowed needs to be pretty clean and level. The pro's of the rear mounted are that you can back it under a lot of stuff that you can't get the mid mount under and it will cut bigger brush. The con's are that it is not a mid mount mower.
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
John Deere 443 4 Row Corn Head (A50774)
John Deere 443 4...
