Mechanos
Veteran Member
Playing around with idea of building a mid-mount weight box for my 955. Do you think there would be any real benefits? or am I wasting my brain power?
...This would put the weight down low and right in the middle where it needs to be and out of the way...
IMO loading tires is best way to add ballast. You won't loose any ground clearance by mounting in the middle and still have use of 3pt hitch arms by not having any ballast box on the rear.
A midmount weight box would add to the tractor's stability on slopes and provide protection for the underside on the machine (like a skid plate, especially if you extend it forward).
It'll help with traction (for all four wheels) if you plow snow.
But as you wrote...not much help in loader operations.
My only concern would be the shock loading of the MMM supports. Having heavy weights that are free to move up and then slam back down seems like it could cause problems unless one keeps things slow and smooth. I know that I certainly wince every time I hit a bump with my 62C and hear it pop up and then get caught by the lift arms... Shock loading systems just never seems to work out well.
